1988 Chevy Cheyenne Oil Pressure
1988 CHEVROLET CHEYENNE
167,000 MILES • 6 CYL • 4WD • MANUAL
AK_PANTHER24
  • 5 POSTS
First off, i live in Alaska. My truck has been sitting for about 2 months and I went to move it the other day. My "Check Gauges" light came on so I looked down and saw that I had no oil pressure. When I tried again I saw the oil pressure climb to about normal but after 10 seconds or so it dropped off again. I just installed a new oil pump this evening and there is no difference in pressure. My first thought was a cracked block but there is no oil in my radiator and no coolent in my oil pan. What would you suggest?
Thank You,
Scott Henrie
Jan 29, 2008 at 9:29 PM
Do you have any type of knocking noise. Best way to handle this is hook up an oil pressure tester-remove the oil sending unit and install here-read off the pressure while engine is idling-is it within specifications-if so replace the oil sending unit.
BTW did you prime the new oil pump thru the distributor.
Jan 29, 2008 at 10:57 PM
AK_PANTHER24
  • 5 POSTS
[quote:70fa57e322="rasmataz"]Do you have any type of knocking noise. Best way to handle this is hook up an oil pressure tester-remove the oil sending unit and install here-read off the pressure while engine is idling-is it within specifications-if so replace the oil sending unit.
BTW did you prime the new oil pump thru the distributor.[/quote:70fa57e322]
Yes, there is a small knocking noise which I honestly don't recall if it was there before I parked the truck. No, I didn't know to prime through the distributor.
Jan 30, 2008 at 12:48 AM
Hook up the oil pressure tester and comeback with the readings
Jan 30, 2008 at 1:30 AM
