1985 Chevy Cheyenne Turns over but won't start
1985 CHEVROLET CHEYENNE
95,000 MILES • 6 CYL • 2WD • MANUAL
COZYPARTONE
It would not fire so I tapped on the distributor cap with a rubber malet and it started twice then would not start again.
Feb 10, 2010 at 10:15 AM
JDL
  • 16,098 POSTS
Welcome to the forum. How long since a tune-up? With engine cranking, you have no spark at the plugs? Key on engine off, I'd check primary voltage at the coil, positive and negative/tach terminal. Engine cranking, the negative side of coil should have a pulse. If no pulse, check the ignition module and pick-up coil.
If the coil is in the cap, you can use a testlite on the tach terminal, the lite should pulse, cranking.
Feb 10, 2010 at 10:41 AM
COZYPARTONE
Thanks for your sugestions, the weather is to bad to try today but will let you know asap.
Feb 11, 2010 at 8:48 PM
