Engine Mechanical problem
1975 Chevy Chevelle V8 Automatic 60000 miles
The back passenger side tire moved forward on drive when on a jack stands and the back driver side tire did not move. When I put the car on neutral and turned the differential, both back tires moved forward. When I turned one back tire, the other one turned to the opposite direction. I put the jack stands on front to see if the front tires will move and they both moved without any problem.
I am currently out of trouble shouting tips and I am in a desperate need for help. By the way, it's a 1975 Chevy Chevelle V8, 350 engine with an automatic transmission.
The transmission fluid level is normal and the differential fluid level is also normal.
Jan 22, 2010 at 10:22 AM
