1972 Chevy Chevelle oil drips from oil fill cap
1972 CHEVROLET CHEVELLE
RICKSS
  • 6 POSTS
Engine Performance problem
1972 Chevy Chevelle V8 Two Wheel Drive Manual
Have oil that drips from the oil fill cap on a 1972, 454. Drops on the header, smokes and stinks and making a mess. Any ideas how to stop it?
Thanks for any help
Aug 27, 2010 at 3:39 PM
Check the condition of the cap if okay-check and test the positive crankcase ventilation system-start at the PCV valve
Aug 27, 2010 at 3:49 PM
RICKSS
  • 6 POSTS
oil cap is in good condition, will replace the PCV. On a 454 should there be 2 PCVs (one on each side) or one will work fine?
Thanks for the reply
Aug 27, 2010 at 4:03 PM
There's only one PCV valve
Aug 27, 2010 at 4:05 PM
RICKSS
  • 6 POSTS
Replaced PVC and oil cap, after a 15 minute drive, problem back again, drips from the oil cap?
Any help???
Aug 30, 2010 at 8:39 PM
Sounds like you need to rebuild the engine due to excessive blowby
Aug 30, 2010 at 9:28 PM
HMAC300
  • 48,601 POSTS
if you have a gauge small enough take teh oil filler cap off and see what the pressure is . if it's above 3psi then something is pressurizing the engine like no breather or blowby. there should be a hose leading to the air cleaner with a small filter to let the engine breathe as well as pcv.
Dec 16, 2010 at 4:10 PM
