1972 Chevy Chevelle Idle Problem
1972 CHEVROLET CHEVELLE
MICADEE
Engine Performance problem
1972 Chevy Chevelle V8 Two Wheel Drive Automatic ? miles
I have a 72 Chevy 350 that runs great as long as I am accelerating. When idling in drive the car seems to miss, it rocks and eventually stalls. when the car is in park or nuetral it idles fine. I just replaced the carb, manifolds, valve covers, spark plugs, distributer cap and rotor, replaced points with electronic ignition...however it was doing this before I did all of that. The only thing I did not replace was spark plug wires and coil...could it be this?
Mar 3, 2009 at 5:35 PM
MIKE H R
  • 3,094 POSTS
there is a tester that will show if a plug is sparking. On a camaro I had did the same thing and found it was a plug wire. When you rev it up the voltage would spark the plug but when ideling it would short out. Also found that plugs act the same at times.
Mar 8, 2009 at 9:47 AM
GMTOY
Have you checked the harmonic Balancer? Aside from the timing if the balancer is damaged you won't get accurate timing.
Aug 23, 2009 at 11:35 AM
