Electrical problem
1971 Chevy Chevelle V8 Two Wheel Drive Automatic
1971 Chevelle 350 engine driving me crazy
After running excellent for several years, and am traveling 70 mph downhill such that engine is not pulling or braking, all of a sudden the tach reads 0 rpm, (acted exactly as if I shut the key off, but the CD player didn�t miss a lick) the car slows down for about 2 seconds, and then is running smoothly again after a loud backfire. I have driven the car several times since then and the problem is getting worse 30 to 40 of these incidents in 200 miles). Three things seem to be consistent; 1) if I punch the accelerator from 0 to 15 mph (low gear), at approximately 2200 rpm, the engine dies (no electrical power to ignition), and then hits again after 1 or 2 seconds. 2) If going up a fairly steep grade (like on-ramp to an overpass) the engine cuts out unrelated to the rpm and I barely get up the ramp. 3) Going on slight down grade and no load on the engine especially if I am traveling over 65 mph the engine cuts out.
The engine never cuts out for more than 1 or 2 seconds, and if I don�t let off the accelerator quickly, I get some really load backfires.
The engine is pretty much original ignition (not electronic). I pulled the tach, to make sure that was not the problem. Been looking for possible short in wiring somewhere. Does anyone have any suggestions? Trying to figure out possible causes.
Sep 25, 2009 at 7:46 PM
