Engine Performance problem
1966 Chevy Chevelle V8 Two Wheel Drive Manual
I have a 1966 chevelle with a 396. This engine is freshly rebuilt with about two hours of run time. The oil is thin and smells strongly of fuel. Other than a sticking float, what may be causing this problem? I have a pressure regulator in line set at 5 psi. I have heard that a fuel pump with a bad diaphram can cause this problem. Any ideas?
Nov 7, 2010 at 8:43 AM
