I have an 86 Chevy celebrity 2.8 v-6 VIN W.
I just replaced cracked heads. Engine starts and runs fine. No engine light.No codes. Thermostat ok. Electric fan won't start at all. Temp light comes on.Fuse ok.No working fan with a/c on.
Installed 3 different relays & fan switches, no fan. Back probed and grounded red terminal on relay and got a light.Grounded green terminal on relay and fan turns on. Manual says to check fusible link C next to starter. Located them but they aren't labeled A,C or F. Does anyone know how to id fusible link C, diagnose it & replaced it. Something else I should check?
Thanks for your help.
Jan 24, 2007 at 1:39 AM
