1987 Chevy Celebrity Engine Problem
1987 CHEVROLET CELEBRITY
25,000 MILES • 6 CYL • FWD • AUTOMATIC
OSCAR4
Car quits, speedometer shuts off, have to re-start to get speedometer to work, engine will surge at idle, have changed speed senor control, did not make a difference. What else could it be? Could it be the map sensor?? If you know what it could be, could you explain where I would find the part on the engine as well.
Thank you for taking the time to answer my question.
Mar 24, 2008 at 2:17 AM
Check the fuel pressure and also the idle air control valve /throttle position sensor.
https://www.2carpros.com/forum/automotive_pictures/12900_iacv_3.jpg
Mar 24, 2008 at 5:05 AM
OSCAR4
Once I replace the Idle Air Control Valve and/or the Throttle Position Sensor does the car then have to be hooked up to a computer to reset automatically?
Mar 24, 2008 at 9:18 PM
Don't be throwing parts to it -inspect/clean/test it-who knows it might not be it. these component are probable causes-to reset just disconnect the battery.
Mar 25, 2008 at 6:00 AM
