first things first-are the dash and tail lights on the same circuit? I'm assuming they are because they both went out around the same time it seems...another thing is i noticed that my dash lights flickered on & off when i adjusted the switch that turns on the headlights(it's a rotating switch for the dashlights and controls the brightness also-but im sure u knew that-duh...) so the fuses are good, im not bad at fixing wires and stuff, but I need to pinpoint the problem and im not experienced enough to do that. Could you give me some sugestions? Here's a tip to help you. When I engage and rotate the lights dimmer switch -the dash lights would flicker? My first guess would be the switch is bad, but why do my headlights work but tail lights and dash light do not? Anyways - any insight on this problem would be most appreciated.
Feb 18, 2009 at 11:50 PM
