Strong Fuel Smell From Air Vent Upon Starting Car
CHEVROLET CAVALIER
BRITTANYJEDI
1. 1993 Chevrolet Cavalier (4-cylinder)
2. 146,000 miles
3. Automatic Transmission
4. Strong fuel smell comes out of the air vents as soon as I start the car. It goes away after a few minutes and does not come back until I turn the car off and restart it. It doesn't happen every time, either. Probably 6 times out of 10.
5. No fluid leaks are present that I'm aware of.
6. I've had to replace my alternator (smell was present before this), my whole front braking system, my coolant backflow (there was a huge hole in the bottom), front sway bars, and that's all I know about. The transmission hasn't been serviced in years, I imagine. The AC works great (smell is present with that too).
The smell doesn't seem to be coming from the back of the car, near the gas tank, or anywhere you'd expect. It literally blows in through the vents. If I have the vents closed and turned off, I can't smell the gas. (I have a very bad sense of smell. I can't even smell food, so smelling the gasoline coming out of my engine is pretty bad. It's very strong.)
Thank you.
Nov 11, 2007 at 8:45 AM
CHEVY22
  • 1,375 POSTS
there is a fuel pressure regulator on the front of your engine , looking at the engine it will be on the drivers side right infront of the valve cover , have some one hit the key and see if yoy have fuel coming out of it , you can also pull the vacuum hose off and check that for fuel , the regulator is most likely the cause ,,,,, let us know
jim
Nov 11, 2007 at 6:13 PM
ADAM750
  • 4 POSTS
had a 97 cavalier do the same thin, dont know of itll help but i had a tiny tiny crack in my fuel injector
Nov 12, 2007 at 7:09 PM
