Speed sensor location and change
CHEVROLET CAVALIER
BLUEFIRESTORM7
I have a 1997 cavalier z24 2.4L twin cam with 160,000 miles. My speedometer is late and only catching my desired speed late. It is not a smooth transition in the speed that is being shown it is choppy. I was lead to believe that is could be my speed sensor. If this is the problem where is it located and how do i change it?
Jun 14, 2007 at 1:40 PM
E40WATER12
  • 522 POSTS
Are u getting a check engine light on?. If youre speedo is bouncy or late reading, Could be youre speedo cluster acting up.
Good Luck.
Jun 15, 2007 at 4:14 AM
BPRICE443
  • 66 POSTS
The speed sensor is usualy located on the trans. closest to the axles.
Jun 26, 2007 at 2:20 AM
PEPEL081
  • 6 POSTS
speed sensor is located on your transmission left side
when your in front....all the way down rear engine you should see it on top right beside the axle...
Jun 27, 2007 at 8:36 PM
