I recently bought 1993 Chevrolet Cavalier RS, 2.2L. I changed transmission oil, engine oil and spark plugs. Everything was fine, then I noticed one of the fuel injectors had a small leak. I took it out changed the gasket and put everything back together. After that car cranked, turned over couple of times and backfired, it was like that for couple of times. I was not cranking excessively but after that when I turn the key it just engaged bendix but would not crank. I tried couple of times and the starter cracked on the nose. I changed the starter, again started very rough, backfired and died right away. After few tries it stoped turning over and same thing. I just cannot afford another starter please help.
Aug 6, 2007 at 8:37 AM
