93 Chev Cavilier
95,000 miles
2 cyl.
NO weird sounds
I replaced the 2 hoses (Top & Bottom) about 6 months ago. No problems until:
It began leaking radiator fluid but not near the hoses that I replaced, not the radiator nor around the radiator, not the reserve tank and not around the engine.
It is near the fire wall and it is a black hose small shaped like a sideways L. When I put my finger over the hose it stops leaking. It is leaking half of the fluids that I put in and keeping the radiator only half full.
Sould this black hose just have a plug on it or does it inter connect with the flow of the radiator fluid system?
If not plugged than what should it connect into for the fluid to stop leaking?
95,000 miles
2 cyl.
NO weird sounds
Jun 29, 2007 at 3:19 PM
