95 Cavalier Z24 2.3L DOHC Quad 4 164,500 miles. I just replaced the crankshaft, main bearing, and rod bearings after having a spun rod bearing. A common problem with the quad 4 I have found. Everything is fine with that, but I'm having a coolant issue. The radiator cap on the resevor leaks bad. I've switched it out with one off another car but that one does the same. I know it's designed to relieve the pressure once it reaches 15 pounds. If I put a cap on it that is not a pressure cap everything is fine. Am I ok with that? What is causing the pressure build up? I can replace a crankshaft, but can't keep coolant in my car. HELP!!!
Apr 27, 2007 at 8:57 PM
