Cavalier brake lights
CHEVROLET CAVALIER
RYANDAIM
I have 99 cavalier with a 2.2 engine. My 2 side brake lights do not work, but my third one does. I have checked the sockets and they are fine. I do not have any voltage at either socket when I press on the brakes. I removed the socket to test the pins and get the same results. The turn signal works fine. I am thinking the turn switch in the column. Is there something I can check or replace?
Mar 6, 2007 at 7:13 PM
MIKE H R
  • 3,094 POSTS
i would vheck the fuses, sometimes the third brake light is on a diferent fuse.
Mar 6, 2007 at 8:21 PM
RYANDAIM
Fuses are good
Mar 7, 2007 at 2:22 AM
RYANDAIM
[quote:713c8d9ad3="M_J_RITZEL"]i would vheck the fuses, sometimes the third brake light is on a diferent fuse.[/quote:713c8d9ad3]
fuses are good
Mar 7, 2007 at 2:24 AM
Try testing the brake switch at the pedal it has to go thru there in order to make it back there.
Mar 7, 2007 at 2:38 AM
CAVALIERDRIVER65
  • 31 POSTS
[quote:36ad5a2022="rasmataz"]Try testing the brake switch at the pedal it has to go thru there in order to make it back there.[/quote:36ad5a2022]
Brake light switch might be the problem. i just had to change mine.
Mar 9, 2007 at 7:51 PM
