AC fan blower
CHEVROLET CAVALIER
BERG
Hi, 1996 Cavalier, Automatic( 3 speed), 90K miles
The AC fan hardly blows on the first and 2nd setting, but works well on the 3rd and 4th seting
Where is the fan located and how do I replace it.
Thank you.
Aug 23, 2007 at 12:26 AM
[quote:32c4b8943b="berg"]Hi, 1996 Cavalier, Automatic( 3 speed), 90K miles
Thank you.[/quote:32c4b8943b]
Your blower motor is doing fine its probably the resistor between the control switch and the motor
The blower motor is on the right side of dash and the resistor is at the evaporator case under the right side of dash.
Aug 23, 2007 at 4:41 AM
LYN
I read a posting regarding the blower fan on a 1996 Cavalier (Aug 2007) & the answer they gave was that the blower was fine but it was possibly the resistor. What is the resistor? Is it possible to replace the resistor? What would be the cost?
Thank you.
Lyn 8)
Oct 29, 2007 at 12:46 PM
The blower motor resistor increases and decreases resistances to control the speed of the motor.
Yes if its bad it can be replace. Have this 2 check-The blower motor relay is in the engine compartment fuse/relay center. The blower motor resistor is at the evaporator case under the right side of dash.
Dunno the cost but the labor will be 0.7 about 45mins.
Oct 29, 2007 at 2:08 PM
