yes i'm new the car is a 95 cavalier automatic its a 2 wheel drive 156,000 miles on it. the car isn't changing gears when your drive. also the speed ominater isn't working. well they checked the sensor to the speed omitor an its not getting power through the wire to the sensor. they already changed transmission fluied an filter. but i should note once in awhile the car will change into gears then it won't everything else is working fine on the car. and where is the BC fuse located at on the car? any help would be much appreciated. Thanks
Pinkcat :D
Pinkcat :D
Jun 26, 2007 at 6:15 PM
