transmission fluid change?
2005 CHEVROLET CAVALIER
58,000 MILES • 4 CYL • FWD • MANUAL
RSNUDDEN
I would like to drain and change the manual transmission oil myself. Where is the fill opening and how do you get it open? Thanks appreciate the info.
Sep 13, 2008 at 3:14 PM
RHALL77
  • 3,361 POSTS
hello,
There are plugs on the side and bottom of the transmission check the last psiot in this thread it shows it.
This guide should help as well.
Fluid Types
Transmission Fluid Type
Type .................... DEXRON III or Equivalent
Capacities
Transmission Fluid
Pan Removal .................... 6.5L (6.9 Qt)
Overhaul .................... 9.0L (9.5 Qt)
Dry .................... 12.2L (12.9 Qt)
Sep 14, 2008 at 2:05 PM
ZWHITE93
I drive a 2004 Chevy Cavalier, 2.2L, A/T. I recently rear ended someone and as a result replaced my radiator, among other things. In the course of this, I lost a good deal of transmission fluid. I had refilled until it overflowed, then siphoned some out. Today I finally jacked my car up and put it on level jackstands. I removed a 7/16" hex that was supposedly a drain for the tranny fluid. From what I've read online, the only way to get the right level is to remove this bolt, and aim for a slow drip. When I removed this bolt, I lost a whopping 12 quarts, yes 3 gallons, of tranny fluid. The bolt was located near where the right front axle goes into the tranny, and was close to the engine oil plug. The capacity is only 7 quarts. What's going on here? I'm positive it was 12 quarts that drained. Now there is a slow drip coming out, but I can't imagine I'm at the capacity I should be at. Did I pull the wrong bolt maybe? Help please!
Apr 3, 2019 at 3:24 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
I'm not sure what you got yourself into here because this transmission doesn't even have a drain plug and the capacity is 7 quarts. It has a level control plug used to check the fluid level but this has to be done with the engine running to get the correct reading. Even dropping the pan would not get the whole 7 quarts out because the rest is in the torque converter.
BECKY BOO
I need to know how do i know when i have enough fluid in my trans, after i change the filter on my car? My car do not have dip stick. Just a orange cap were you pour the fluid.
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_625.jpg
FIG. 2
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_62.jpg
There is a little bit of conflicting info in this post. The Cavalier has a plug that you have to use in order to check the fluid level. The diagram above is correct but I am attaching the entire process from the manual that will take you step by step.
Here is a guide that has good info for those transmissions that have a dipstick:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Please see the attached information for exactly how to perform the fluid checking process.
Thanks
May 8, 2022 at 2:40 PM
