easy way to remove the brake rotors to replace the pads?
2005 CHEVROLET CAVALIER
55,000 MILES • 4 CYL • FWD • AUTOMATIC
BOGIE71
Is there a trick or easy way to remove the brake rotors to replace the pads?
Feb 23, 2008 at 9:01 PM
Replacing front brake pads and rotors really isn't too hard. You can expect to get around 25,000 miles from a set of pads, but that is based on driving habits and terrain. Changing them yourself can save you a lot. If you get lifetime parts from a parts store and do it yourself, you shouldn't have to pay for brake pad replacement again.
First, here is a link that shows in general how the process is done:
Here are the directions specific to your vehicle. The attached pics correlate with the directions.
2005 Chevrolet Cavalier L4-2.2L VIN F
Brake Pads Replacement
Vehicle Brakes and Traction Control Disc Brake System Brake Pad Service and Repair Procedures Brake Pads Replacement
BRAKE PADS REPLACEMENT
Caution: Refer to Brake Dust Caution in Service Precautions.
Caution: Refer to Brake Fluid Irritant Caution in Service Precautions.
Removal Procedure
pic 1
1. Inspect the fluid level in the brake master cylinder reservoir.
2. If the brake fluid level is midway between the maximum-full point and the minimum allowable level, no brake fluid needs to be removed from the reservoir before proceeding.
3. If the brake fluid level is higher than midway between the maximum-full point and the minimum allowable level, remove brake fluid to the midway point before proceeding.
4. Raise and support the vehicle. Refer to Vehicle Lifting.
5. Remove the tire and wheel assembly.
6. Install and firmly hand tighten 2 wheel nuts to opposite wheel studs in order to retain the rotor to the hub.
7. Install a large C-clamp over the body of the brake caliper with the C-clamp ends against the rear of the caliper body and against the outboard brake pad.
8. Tighten the C-clamp evenly until the caliper piston is compressed into the caliper bore enough to allow the caliper to slide past the brake rotor.
9. Remove the C-clamp from the caliper.
pic 2
10. Fully loosen the caliper bolts (1, 4) from the steering knuckle (3).
pic 3
Notice: Support the brake caliper with heavy mechanic's wire, or equivalent, whenever it is separated from it's mount and the hydraulic flexible brake hose is still connected. Failure to support the caliper in this manner will cause the flexible brake hose to bear the weight of the caliper, which may cause damage to the brake hose and in turn may cause a brake fluid leak.
11. Without disconnecting the hydraulic brake flexible hose, remove the caliper assembly (2) from the steering knuckle. Support the caliper with heavy mechanic's wire (1), or equivalent.
pic 4
12. Remove the brake pads from the caliper.
pic 5
13. Remove the disc brake caliper bolts (1) from the caliper assembly (3).
14. Inspect the caliper bolts (1) for rust, corrosion and/or damage.
15. If the bolts are rusty, corroded, and/or damaged, replace the bolts (1) and replace the bushings (2).
Installation Procedure
pic 6
1. Install a large C-clamp (2) over the body of the brake caliper (1), with the C-clamp ends against the rear of the caliper body and against an old inboard brake pad or a wood block installed against the caliper piston.
2. Tighten the C-clamp (2) evenly until the caliper piston is compressed completely into the caliper bore.
3. Remove the C-clamp and the old brake pad or wood block from the caliper.
pic 7
4. Lubricate the caliper bushings and install the caliper bolts to the caliper.
Important: The outer brake pad must be mounted with the leading edge of the wear sensor facing the brake rotor during forward wheel rotation, or at the top of the pad when installed in vehicle position.
5. Install the brake pads to the caliper.
6. Thoroughly clean the brake pad mating surface on the steering knuckle of any surface debris and/or corrosion.
7. Apply a thin layer of high temperature silicone brake lubricant to the brake pad mating surface on the steering knuckle.
pic 8
8. Install the caliper assembly (2) to the steering knuckle (3).
Notice: Refer to Fastener Notice in Service Precautions.
9. Tighten the caliper bolts (14) to the steering knuckle (3).
^ Tighten the bolts to 51 Nm (38 ft. lbs.).
10. Remove the wheel nuts securing the rotor to the hub.
11. Install the tire and wheel assembly.
12. Lower the vehicle.
13. With the engine OFF, gradually apply the brake pedal to approximately 2/3 of its travel distance.
14. Slowly release the brake pedal.
15. Wait 15 seconds, then gradually apply the brake pedal approximately 2/3 of its travel distance again until a firm brake pedal apply is obtained. This will properly seat the brake caliper pistons and brake pads.
16. Fill the brake master cylinder reservoir to the proper level.
17. Burnish the pads and rotors.
_________________________________________________
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Feb 19, 2021 at 7:51 PM
