Follow lower radiator hose to water pump and you will find thermostat.
Here are procedures for installation and removal for 2.2L engine:
If your eighth digit in VIN is 4:
REMOVAL:
Drain the cooling system.
Remove the lower radiator hose from thermostat outlet.
Remove the thermostat outlet bolts and outlet
Remove the thermostat.
Clean the mating surfaces of the radiator outlet and the radiator outlet pipe
INSTALLATION:
Install the thermostat.
Install the thermostat outlet and bolts.
Install the coolant outlet attaching bolts and tighten the thermostat outlet bolts to 10 ft. lbs. (14 Nm).
Install the lower radiator hose to thermostat outlet.
Fill the cooling system.
Inspect for leaks.
If your eighth digit in VIN is F:
REMOVAL:
If equipped with an automatic transmission, remove the exhaust manifold.
Remove the thermostat housing to water pump feed pipe bolts.
Remove the thermostat housing to water pump feed pipe.
INSTALLATION:
Install the thermostat housing to water pump feed pipe.
Install the thermostat housing to water pump feed pipe bolt and tighten the thermostat housing to water pump feed pipe bolt to 89 lb inches (10 Nm).
If equipped with an automatic transmission, install the exhaust manifold.
Mar 1, 2018 at 5:15 PM
(Merged)
