Remove the upper trim finish panel from the front door. Remove the mirror sound absorber
Disconnect the mirror electrical connector (if equipped)
Remove the mirror nuts
Remove the mirror from the door
Position the new mirror to the door
Install the mirror nuts and tighten to 53 Lb In ( 6 Nm)
Connect mirror electrical connector (if equipped)
Install the mirror sound absorber
Install the front door upper trim finish panel
Jul 15, 2009 at 3:09 PM
