2004 Chevy Cavalier Head lights
2004 CHEVROLET CAVALIER
77,000 MILES • 4 CYL • AWD • AUTOMATIC
JESHIE10
When I went to my car I turned it on and put it in gear. When I did the day time running lights indecator light flashed and then the service light came on. I turned on the lights and there was nothing but there was high beams. I have changed the head lights. Put a resister switch in and the actual switch that is on the steering wheel and nothing has worked. Any ideas? I also took it to the Chevy dealer and they had it on the computer for 3 hours and said nothing was wrong.
Aug 11, 2008 at 5:21 PM
2CARPRO JACK
  • 11,533 POSTS
In the interior fuse panel is a relay for the DRL's it also feeds the headlights, try swapping it with another relay (a/c) and see if it fixes it.
Aug 12, 2008 at 7:54 AM
JESHIE10
I tried that....still nothing
Aug 12, 2008 at 4:24 PM
2CARPRO JACK
  • 11,533 POSTS
both headlight fuses in the underhood power center have power and are good?. If so get a test light and seeif you have power out of the headlight switch at the dark blue wire
Aug 13, 2008 at 7:42 AM
