2004 Chevy Cavalier clutch problem
2004 CHEVROLET CAVALIER
107,000 MILES • 4 CYL • 2WD • MANUAL
DSCHLOE
Clutch pedal goes to the floor and will not come back up master cylinder is not leaking but clutch will not disingauge clutch. do you think it's the master or the slave cylinder. thanks
Sep 13, 2008 at 8:31 AM
2CARPRO JACK
  • 11,533 POSTS
If the master isnt leaking it could be the slave. Is it leaking? If there are no leaks at all and fluid level is good, the master may have a bad seal in it and is bypassing internally
Sep 13, 2008 at 8:33 AM
DSCHLOE
their appears to be no leaking at all. level is good. the pedal just slowly went away their was no slipping of the clutch at all. just lost the pedal
Sep 13, 2008 at 8:38 AM
2CARPRO JACK
  • 11,533 POSTS
could be a bad master. Best way to check is to get a plug for where the line goes into master and see if the master will hold pressure on its own, if it will then you know the problem is downstream, otherwise it is master
Sep 13, 2008 at 9:20 AM
DSCHLOE
Thanks I'll try it.
Sep 13, 2008 at 9:32 AM
