2004 Chevy Cavalier clutch
2004 CHEVROLET CAVALIER
162,000 MILES • 4 CYL • FWD • MANUAL
ROBW24
I have a 04 Chevy Cavalier, the clutch pedal went to the floor and i cant shift gears. the slave cylinder resovoir was empty and fluid was leaking from an opening at the bottom of the trans. What could be the problem? If the slave cylinder is bad do i have to replace the whole clutch?
Sep 22, 2010 at 6:39 PM
SATURNTECH9
  • 30,869 POSTS
The slave cylinder is inside your transmission bell housing so sound's like it leaked.With the mileage you have i would replace the clutch too.It might even have leaked into the clutch if that happened then you will have to replace the clutch.
Sep 22, 2010 at 6:52 PM
