Electrical problem 4 cyl Two Wheel Drive Automatic 27800 miles
My car was making a weird but fairly faint high-pitched squealing/squeaking noise anytime I was moving, seemed most prominent around 35-45 mph, which stopped if I even touched the brakes or cut the wheel even slightly to the left. Then one morning, the noise was gone, but the blinkers don't work at all. When I 'turn on' the blinkers, there's no clicking noise, no flashing light either internally or externally, no response at all. Fuse seems fine. Ideas? Also, the car has intermittently had issues with the speedometer and tachometer getting "stuck" and registering varying reading/speeds much higher than average. That problem might only last a day and resolve the next time I crank up . . . or it might last a week or more and the gauges seem to almost 'deflate,' meaning that the needle is a little lower each day until they return to normal. Do I need Holy Water?
Oct 15, 2008 at 9:24 PM
