Hey DONNASENSKE1964,
The entire transmission takes about 12 quarts but if you are just doing the pan and filter it will take about 5.
Fluid Types
Transmission Fluid Type
Type .................... DEXRON III or Equivalent
Capacities
Transmission Fluid
Pan Removal .................... 6.5L (6.9 Qt)
Overhaul .................... 9.0L (9.5 Qt)
Dry .................... 12.2L (12.9 Qt)
Here is a guide showing you how to do the job if you are replacing the filter.
You will need to raise the vehicle to gain access to the drain plug on your trans axle. Place a container underneath the plug (make sure it can hold 6 quarts of fluid). Replace the fluid with Dexron VI or equivalent ATF (please note of any metal fragments in the transmission fluid as this will indicate the level of wear). Fill to 75% capacity to account for any fluid left in the transmission. Move through all gear selections while engine is running 2 times pausing for 10 seconds between selections. Place back into park and recheck for proper fill while the engine is idling. Take it for a drive at both stop and go traffic and on expressway to ensure fluid has properly circulated. Upon return, Recheck again while idling in park.
Please let us know happens so it will help others.
Best, Ken
Feb 14, 2017 at 7:35 AM
