2003 Chevy Cavalier Cooling fan won't turn
2003 CHEVROLET CAVALIER
113,000 MILES • 4 CYL • FWD • AUTOMATIC
JSTRLE
Over the winter I went into the ditch and snow blocked the fan from moving I did not realize this right away, and I think the fan motor burnt out. The fan will work for a couple minutes when I change the fuse under the hood, but the fuse continues to blow and the check engine light comes back on. You can only drive for about a minute or two before the fuse will blow again.
Apr 12, 2008 at 11:53 AM
BLACKOP555
  • 10,386 POSTS
what is the check engine light code showing?
sounds like the motor may be shorting out or its related to the temperature switch.
Apr 12, 2008 at 12:44 PM
