I hear the fuel pump kick on and run
2003 CHEVROLET CAVALIER
120,000 MILES • 4 CYL • FWD • AUTOMATIC
TRAVIS01
won't start i am not getting enough fuel to start it i have changed the fuel filter and the pressure regulator and still nothing. i dump gas into the throttle body and it starts and runs till it runs out of gas but i hear the fuel pump kick on and run what should i do
Jun 15, 2010 at 4:45 PM
SQM
  • 6,383 POSTS
Have you tested to see if the pump is producing correct amount of fuel pressure?
Should be between 50-60 PSI with key on, engine off.
You might find this articles helpful:
Here is a video of replacement procedure:
https://youtu.be/Lhd0vd8pdBU
I have attached test procedure for the pump and replacement.
Any questions please let me know.
Thank you.
Jul 15, 2021 at 12:52 PM
