In order to get those rivets out, you will have to drill them.
All you want to do is to use a drill bit slightly smaller than the rivets and drill. This will break the rivets and loosen the window motor regulator.
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
I have attached the replacement procedure below for your reference.
Thank you.
Feb 3, 2022 at 8:37 PM
