2002 Chevrolet cavalier, My problem started with my car making a weird sound when I start it and it only happens when its cold and goes away as the car warms up then it would run fine and would not make any noise when starting en less the car had cooled down for a few hours. The sound was like it was low on power steering fluid but the fluid level was OK.
I took the car to a shop and they replaced the power steering pump, and the problem only got worse. now the car has the original problem with the noise, and the new pump makes a winding sound whenever i give it gas. I took it back to the shop and they put some cleanser in the power steering fluid. The cleanser didnt help much Ive put 300 miles on the car and the problems are still there.What do you think could be causing this ?
Nov 1, 2009 at 1:21 AM
