2002 Chevy Cavalier Low idle
2002 CHEVROLET CAVALIER
KERRIS
Engine Mechanical problem
2002 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
I have a 2002 cavalier with a ecotech motor and automatic transmision. The car idle's low and when I slow down or come to a stop it goes to shut off. Also if I turn on the heat, radio, or anything else on in the car it will automaticly shut off. The only time I can run these things is if I am on the highway
Feb 27, 2010 at 7:13 PM
Clean out the idle air control valve and EGR valve and test the TPS/MAP sensors to include a fuel pressure check-
Feb 27, 2010 at 8:27 PM
KERRIS
Thank you I will try that
Mar 2, 2010 at 3:04 PM
