2002 Chevy Cavalier Cluster panel not working
2002 CHEVROLET CAVALIER
58,000 MILES • 4 CYL • FWD • AUTOMATIC
AROSS61175
I have no gas gauge, no temp gauge, no speedometer, no odometer, no rmp, when i start the car the only lights i get on the instrument panel are the thieft systen and check engine light but they go off like they should once car is started, everything else works, even my dash lights work. I have checked fuses, and none were blown relaced them just in case what do i do now???
Jun 3, 2008 at 7:16 PM
SERVICE WRITER
  • 9,123 POSTS
Most likely a faulty instrument panel cluster (IPC) or a Body Control Module-(BCM), possible a reflash on the BCM may work.
I am only aware of being able to test the IPC with a scanner that will allow you to control the gauges manually.
Jun 3, 2008 at 7:58 PM
STARBLAZ
[quote:4156de79b5="aross61175"]Electrical problem
2002 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 58000 miles
I have no gas gauge, no temp gauge, no speedometer, no odometer, no rmp, when i start the car the only lights i get on the instrument panel are the thieft systen and check engine light but they go off like they should once car is started, everything else works, even my dash lights work. I have checked fuses, and none were blown relaced them just in case what do i do now???[/quote:4156de79b5]
I have the same problem...anyone out there have an answer?
[email protected]
Jul 4, 2008 at 7:22 PM
