Engine overheats, fan won't come on, fuses insde the car and under the hood are fine, I changed the fan relay, fan still won't come on. I bought a coolant sensor, however I have not put it in, I want to see if there might be something else to check. I put power to the fan with a jumper wire and it works
Thank you, Tony
Thank you, Tony
May 7, 2009 at 10:52 PM
