i have a 2001 cavalier z24 at idle it is at 1700 RPM i have tryed the IAC valve, MAP sensor, and TP sensor i did not find any vaccum leaks the temp sensor is good. i am out of ideas. the sensors should use 5v power supply i tested it and it has a 7.34v power supply on the MAP sensor and the TP sensor. would that voltage change the readings and cause it to idle high? would it be the computer?
Jan 4, 2009 at 2:50 PM
