2001 Chevy Cavalier Has no spark
2001 CHEVROLET CAVALIER
60,000 MILES • 4 CYL • FWD • AUTOMATIC
DEEDEE1
  • 4 POSTS
car has no spark. What could the problem be? replaced the plugs,wires and coil packs. has a new baterry,alternator,,and starter,and a crank sensor. what else could the problem be?
Oct 15, 2010 at 12:16 PM
JDL
  • 16,098 POSTS
Also, check B+ and ground at the ignition module. The pink wire is voltage, goes hot when you turn on the key. Black wire is ground.
https://www.2carpros.com/forum/automotive_pictures/170934_cavalier_ignition_module_1.jpg
Oct 15, 2010 at 12:24 PM
DEEDEE1
  • 4 POSTS
where are they located
Oct 15, 2010 at 12:27 PM
JDL
  • 16,098 POSTS
The coil pack sits on top of ignition module. Top rear of engine. I looked at 2.2L engine, vin4.
Oct 15, 2010 at 12:37 PM
DEEDEE1
  • 4 POSTS
Is it the ignition module that's bad?
Oct 15, 2010 at 12:47 PM
JDL
  • 16,098 POSTS
It's possible,but, without a little testing, can't be sure. I hate to see you throw parts at it.
Oct 15, 2010 at 12:59 PM
DEEDEE1
  • 4 POSTS
what testing would have to be done. the car don't start to take it to a garage and have no money for a tow
Oct 15, 2010 at 1:09 PM
JDL
  • 16,098 POSTS
Use a testlite between pink and black wire, key on, see if lite comes on. Use a noid lite check for injector pulse, engine cranking.
Oct 15, 2010 at 1:40 PM
