2000 Chevy Cavalier sputtering
2000 CHEVROLET CAVALIER
20,000 MILES • 4 CYL • 2WD • MANUAL
SNM*BELIEVE
The cavalier sputters in cold weather at a constant speed. It does not do it n hot weather, only in cooler temps. Acceleration is fine but at a constant rate of speed it starts sputtering doesn't matter if its 25 miles per hour or 55 miles per hour.
Sep 18, 2010 at 12:29 PM
Has the check engine light come on? Have you checked fuel pump pressure?
Sep 18, 2010 at 10:04 PM
SNM*BELIEVE
No the check engine light hasn't came on. We replaced the fuel pump about a year ago or less and it started doing this after wards. How do you check the pressure? And should there have been something that needed reset after we changed it? Thanks
Sep 19, 2010 at 1:05 AM
Nothing to reset. Here is a how to for checking fuel pump pressure.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Sep 20, 2010 at 6:07 AM
SNM*BELIEVE
Ok so I am going to check the fuel pressure. Where is the relay if that needs to be replaced?
Sep 20, 2010 at 9:43 AM
It is under the hood in the power distribution center.
Sep 21, 2010 at 1:31 AM
