2000 Chevy Cavalier Loss of power = problems
2000 CHEVROLET CAVALIER
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
IRONMAN0509
Okay so here's my problem...my car starts up fine without any problems. I put the car in drive and start along my way. My Service Light pops on as well as my Theft System light sometimes. Then all of a sudden as I continue to drive on my cars lights and electrical components start to dim or operate at about half of normal i.e. the panel lights are dim when switched to full power, my AC blower slows to almost nothing at full power, my headlights are dimmed, and my windshield wipers go about half as fast as they normally would. When this happens I find that everything will operate normally if I accelerate but as soon as I let off the gas it goes back to half power. Does not stop there...all of a sudden my Check Gauges light will come on and then my heat meter will drop to 0. Sometimes my speedometer, fuel, and RPM meters will also drop to 0 but again will return to normal as I accelerate. Also notice that when I brake my lights will also dim. Finally sometimes my Brake land ABS light will come on, sometimes for a moment and sometimes until I turn my car off. Unfortunately this does not happen all the time...sometimes none of the above mentioned stuff will occur while I am driving...other times everything happens. Also another interesting point is that sometimes when the electrical system is running half as well it will return to full power aka will stay completely 100% without me accelerating the engine. IMPORTANT NOTE: I took it into a shop and they said it was the alternator so I had that replaced a little over 12 hours ago and they said that my battery was worn out so they replaced that as well. Literally as I started up my car the same thing happened again, this time with a brand new alternator and battery. PLEASE PLEASE PLEASE help me...after that alternator job I'm down $500+ for services that did NOT fix my problem and am hoping that you will be able to provide me with the right information to avoid anymore unnecessary spending. Thank you very much for your time.
Sep 6, 2009 at 2:42 AM
MERLIN2021
  • 17,250 POSTS
If this happened to me, I would MAKE the shop that diagnosed the alternator and battery fix it free, this was thier call. Small claims court will give you your money back, and it might be worth saying, "I am giving you the opportunity to fix it, or I am going to court". That said, it could be a ground wire problem, negative battery cable needs replacing, Or a short in some wire. Any fuses blown?
Sep 6, 2009 at 7:44 AM
IRONMAN0509
I plan on talking to the guys tomorrow since they are not working today. I checked the fuses they are fine. However I checked the negative battery cable and noticed that there is an area of exposed wire that sat right along the metal stand that the battery sits on. Also I was wondering where the ground wire would be connected at along the chassis or body. Thoughts?
Thanks a ton,
Larry
Sep 7, 2009 at 10:22 AM
MERLIN2021
  • 17,250 POSTS
Negative cable should bolt to the engine block. Some do have a secondary grounding piont near the tray, does it have a clamp attached there?
Sep 8, 2009 at 6:26 AM
