2000 Chevy Cavalier Air conditioner is not blowing cold air
2000 CHEVROLET CAVALIER
101,000 MILES • 4 CYL • FWD • AUTOMATIC
BLUEEYESLBS
I have been in and out of the repair shop this summer and last. My car was thought to have a leak and could not find it. Several times I believe freon/coolant was put in. Couldn't find the leak even when putting dye though the system when it was flushed. Finally replace a part but still had a problem with cold air and a leak. Went through the dash...I don't believe that helped, but cost me $600. The air continues to come out but it is not cold. (I also had problems with my turn signals not wanting to turn off by themselves but the shop did fix that when I went in the last time.) Also, my seat belt light has come on even though I am wearing my seat belt.
Thank you for any suggestions in advance!!
The shop has checked for several leaks by replacing the fluids, flushing out the system and replacing a part that they had to go through the dash of my car? How can I fix this problem?
Jun 4, 2008 at 4:09 PM
RHALL77
  • 3,361 POSTS
did they check the seals around the compressor and the lines at the compressor. these do leak allot. the dye might be very slight at the compressor seal.
Jun 4, 2008 at 4:21 PM
