1999 Chevy Cavalier Starts fine, then really rough idle, an
1999 CHEVROLET CAVALIER
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
IDRIVEAG
I will start the car and everything seems fine. I drive down the road for a block and something happens, like a small hiccup and then no matter how much gas I give it, it has no power or rev up. If I back off the gas and then lightly press I get power back. At idle the car is super rough like a dropped cylinder but when I disconnect the electrical connector from the alternater it smooths right out. So I drove it with this connector disconnected and I never lost power. The alternater was tested good, so what is downstream that could be fouling this up? I just replaced the fuel pump, fuel regulator, and filter, and map sensor. Help please!!
Apr 12, 2010 at 1:57 PM
KHLOW2008
  • 41,814 POSTS
Hi idriveag,
Thank you for the donation.
The alternator charging is also controlled by the PCM and from the symptom description, you might have a faulty PCM.
You would need to get it tested.
Apr 14, 2010 at 12:27 PM
