1999 Chevy Cavalier power window motor
1999 CHEVROLET CAVALIER
14,000 MILES • 4 CYL • FWD • AUTOMATIC
TEFCF199
i have the motor loose, but don't know how to get regulator and motor seperated. What is the trick?
Jan 20, 2010 at 3:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
thanks for the donation! you will have to remove the regulator and motor as an assembly. then you need to drill out the rivets that secure the regulator and window motor together. below are the steps to getting the motor / regulator assembly out of the door. REMOVAL: Remove the door panel and the water deflector. Remove the door glass (window). On front door regulators only, remove the regulator retaining bolts. Using a 3 / 16 in. (5mm) drill bit, drill out the regulator attaching rivets. Move the regulator rearward and disconnect the wiring harness from the motor. Disengage the roller on the regulator lift arm from the glass sash channel. Remove the regulator and motor through the rear access hole. Regulator retaining bolts
https://www.2carpros.com/forum/automotive_pictures/261618_1_93.jpg
Regulator retaining rivets
https://www.2carpros.com/forum/automotive_pictures/261618_2_77.jpg
Front door regulator assembly
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1467.jpg
INSTALLATION: Attach the motor to the regulator using a rivet tool and 3 / 16 in. (5mm) rivets or 3 / 16 in. (5mm) nuts and bolts. Place the regulator through the rear access hole into the door. Connect the wire connector to the motor prior to installing the regulator in the panel. Locate the lift arm roller into the glass sash channel. Using rivet tool J-29022 or equivalent, rivet the regulator to the door using 1 / 4 in. x 1 / 2 in. (6mm x 13mm) aluminum peel type rivets (part No. 9436175 or equivalent). On the front door only, install the regulator retaining bolts Replace the door window assembly. Install the water deflector and the door panel.
Jan 20, 2010 at 10:02 PM
