Driver door latch
1999 CHEVROLET CAVALIER
BRANDONCOURTY
Interior problem 4 cyl Two Wheel Drive Automatic
Hi. I opened my door this morning and started the car. i went to close the door but it would not latch. It was -10 degrees celcius. i tried to close the door while i held the handle in the upper position then let go when i closed the door, but nothing happened.
Dec 8, 2008 at 2:55 PM
It sounds like the door latch itself is broken and needs replacement. You will need to take the door panel off before you can replace the latch.
Here is a guide that will give you an idea of what you are inf for.
https://www.2carpros.com/articles/door-panel-removal
Jan 23, 2018 at 5:46 PM
