1998 Chevy Cavalier window replacement
1998 CHEVROLET CAVALIER
190,000 MILES • 4 CYL • 2WD • AUTOMATIC
DIEHLMALIKIE
i broke out my window on accident. i found a reasonably priced replacement for it. i need to know how to remove the back driver side passenger window of a 2 door coup. also how to install it in the car.
Dec 13, 2008 at 6:39 PM
MMPRINCE4000
  • 8,548 POSTS
You need to remove the door handle, window crank (or PW switch) and interior door handle. The door panel is held in place with plastic retainers and pulls out.
Generally on GM cars the window is riveted to the regulator and the rivets must be drilled out and replaced with bolts. Once the rivets are drilled out, you can remove the window (sort of cock it 45 degrees) and pull out. You would have to loosen the regulator bolts to the door for more clearence.
Dec 15, 2008 at 7:01 AM
