1998 Chevy Cavalier cooling fan
1998 CHEVROLET CAVALIER
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
W0256136
If my cooling fan is not working and I just replaced it. What should I do? Could it be my wiring is bad or the fan might be bad>
Dec 21, 2008 at 12:07 AM
MMPRINCE4000
  • 8,548 POSTS
Generally you can test the fan switch by unpluging it. The fan should run all the time, also try turning the AC on, the fan should run at a slower speed.
If none of this works, then it is probably the fan relay or a fuse.
Dec 21, 2008 at 9:31 AM
