If my cooling fan is not working and I just replaced it. What should I do? Could it be my wiring is bad or the fan might be bad>
Dec 21, 2008 at 12:07 AM
MMPRINCE4000
CERTIFIED EXPERT
Generally you can test the fan switch by unpluging it. The fan should run all the time, also try turning the AC on, the fan should run at a slower speed.
If none of this works, then it is probably the fan relay or a fuse.
