There is a high-pitched rattle on the right side of the engine compartment that varies in intensity with engine speed. The air conditioner does not work.
Dealer says the AC compressor clutch is worn and I need to spend $1000 to get a new AC compressor installed. What do you say?
If I need a compressor, is a used one generally a "safe bet"? Is this a do-it-yourself job? What tools are needed? What does the AC compressor and clutch look like? Are they sold separately? If I elect to repair myself, what are the required tools? Can you share a "short list" of repair tips to help the process along? Thanks for any suggestions!
Oct 24, 2007 at 9:01 AM
