I have a 1998 Cav with a shift problem, I pulled the codes and they show up as follows:
PO121 Throttle/Pedal position sensor/Switch A Circuit range/Performance Problem
and
PO122 Throttle/Pedal position sensor/Switch A Circuit low input
Can anyone tell me if "Throttle/Pedal position sensor" is the name I would give AutoZone or someone to get the sensor or is there a different name, and also where is it located on the vehicle?
Thanks in Advance
Chris
and
Thanks in Advance
Chris
Jun 28, 2007 at 8:54 AM
