1997 Chevy Cavalier Hesitation
1997 CHEVROLET CAVALIER
112,000 MILES • 4 CYL • FWD • AUTOMATIC
CARRAT
noting some intermittent hesitation w. pedal
usually when stopped and beginning to start
sometimes roar
then ok
need motor mounts and is due for spark plugs
also getting traction sensor light (R front Hub)
what are you thoughts?
Jun 28, 2009 at 6:17 PM
BUDDYCRAIGG
  • 2,262 POSTS
maybe a brake caliper is hanging up on the right front.
Jun 28, 2009 at 6:24 PM
Engine hesistation could be caused by the following
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jun 28, 2009 at 6:25 PM
