1997 Chevy Cavalier disconnecting AC compressor
1997 CHEVROLET CAVALIER
160,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVEB54
On my cavalier I here a rattling noise when AC or defrost is used.I imagine the bearings are going out in compressor/clutch? Can't afford new one now so is there a way to disconnect or disengage the clutch so I can use defrost this winter without making this problem worse?
Thank you!
Sep 12, 2008 at 10:29 AM
PEAR69
  • 1,482 POSTS
The a/c compressor clutch is electric. Simply unplug the electrical connector that plugs into the a/c clutch. Your check engine light will come on but it should not effect the engines performance.
Be aware that your defrost works on conditioned (dry) air. It will no longer keep your windows from fogging up but it will blow heated air to thaw out the ice on cold days.
The rattle may indicate that your refrigerant needs a little charge. Any autoparts store sells small cans of refrigerant, they even come with a pressure gauge to be sure you put enough in.
Sep 12, 2008 at 3:29 PM
