Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Cavalier
Trouble Codes
P Codes (Powertrain)
P0100 - P0199
P0134
1997 Chevy Cavalier Code PO134
1997 CHEVROLET CAVALIER
225,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCOTTSBAYGIRL
MEMBER
FOLLOW
code PO134 appears, comes back even after changing O2 Sensor
Feb 6, 2010 at 4:38 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
You will need to check the circuit back to the ECU, i feel that this is a wiring fault.
mark, mhpautos
Feb 6, 2010 at 4:43 PM
SCOTTSBAYGIRL
MEMBER
it's fine untill engine reaches operating temperature then the PO134 code comes back again
Feb 6, 2010 at 4:50 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
P0134 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
I would still be checking the continuity back to the ECU as you say the sensor has been replaced, otherwise you may be looking at an ECU internal fault.
mark, mhpautos
Feb 6, 2010 at 8:20 PM
